10.10.2016, 15:49 (15:49) | #222 |
Ребята помогите новичку расшифровать ошибки.
Monday,10,October,2016,11:01:56:05031 VCDS -- Windows Based VAG/VAS Emulator Running on Windows 7 x64 VCDS Version: 15.7.1.0 (x64) Data version: 20150904 www.Ross-Tech.com VIN: WVGZZZ7LZ8D025464 License Plate: 1 Mileage: 194900km-121105mi Repair Order: -------------------------------------------------------------------------------- -------------------------------------------------------------------------------- Chassis Type: 7L (6N0) Scan: 01 02 03 05 08 09 15 16 17 18 19 22 34 46 55 56 68 76 VIN: WVGZZZ7LZ8D025464 Mileage: 194900km-121105miles 01-Engine -- Status: OK 0000 02-Auto Trans -- Status: OK 0000 03-ABS Brakes -- Status: OK 0000 04-Steering Angle -- Status: OK 0000 05-Acc/Start Auth. -- Status: OK 0000 08-Auto HVAC -- Status: Malfunction 0010 09-Cent. Elect. -- Status: Malfunction 0010 15-Airbags -- Status: OK 0000 16-Steering wheel -- Status: OK 0000 17-Instruments -- Status: OK 0000 18-Aux. Heat -- Status: Malfunction 0010 19-CAN Gateway -- Status: OK 0000 22-AWD -- Status: OK 0000 34-Level Control -- Status: Malfunction 0010 42-Door Elect, Driver -- Status: Malfunction 0010 46-Central Conv. -- Status: Malfunction 0010 52-Door Elect, Pass. -- Status: OK 0000 55-Headlight Range -- Status: Malfunction 0010 56-Radio -- Status: OK 0000 62-Door, Rear Left -- Status: OK 0000 68-Wiper Electr. -- Status: OK 0000 72-Door, Rear Right -- Status: OK 0000 76-Park Assist -- Status: OK 0000 ------------------------------------------------------------------------------- Address 01: Engine Labels: None Part No SW: 070 906 016 DD HW: 070 906 016 DE Component: R5 2,5L EDC G000AG 1106 Revision: --H05--- Serial number: VWX3Z0G1648183 Coding: 0010175 Shop #: WSC 00000 256 01574 VCID: 55A6197BFF12F1965E-5072 No fault code found. Readiness: 0 0 0 0 X ------------------------------------------------------------------------------- Address 02: Auto Trans Labels: 09D-927-750.lbl Part No SW: 09D 927 750 CL HW: 09D 927 750 CL Component: AL 750 6A 1096 Revision: 00H61000 Serial number: Coding: 0004456 Shop #: WSC 31414 790 00001 VCID: 7AFC6AC736CCFEEE13-5072 No fault code found. ------------------------------------------------------------------------------- Address 03: ABS Brakes Labels: 7L0-907-379-MK25E1.clb Part No SW: 7L0 907 379 K HW: 7L0 907 379 K Component: ESP ALLRAD MK25E1 0302 Revision: 00H53001 Coding: 0000386 Shop #: WSC 31414 790 00001 VCID: 418EDD2B1C9A6D3612-8014 No fault code found. ------------------------------------------------------------------------------- Address 05: Acc/Start Auth. Labels: 3D0-909-13x-05.lbl Part No SW: 3D0 909 139 B HW: 5WK 485 04 Component: Kessy 6840 Revision: 68406620 Serial number: VWX3Z0G1648183 Coding: 0000232 Shop #: WSC 31414 790 00001 VCID: 2858608F9FE0BC7E35-807C Subsystem 1 - Part No: XXXXXXXXXXX Component: ELV XXXX No fault code found. ------------------------------------------------------------------------------- Address 08: Auto HVAC Labels: 7L6-907-040.clb Part No: 7L6 907 040 AE Component: CLIMAtronic R/L 4326 Coding: 0001020 Shop #: WSC 49049 001 1048576 VCID: 73E247E316A68FA650-8026 1 Fault Found: 01592 - Air Quality Sensor (G238) 010 - Open or Short to Plus ------------------------------------------------------------------------------- Address 09: Cent. Elect. Labels: 7Lx-937-049-V2.clb Part No SW: 7L6 937 049 AF HW: 7L6 937 049 AF Component: J519 2000 Revision: -0004--- Serial number: -------------- Coding: 6000040038229C080000000000000000 Shop #: WSC 31414 790 00001 VCID: 0008182F5710A43E5D-8054 4 Faults Found: 01493 - Bulb for Blinkers; Front Left (M5) 011 - Open Circuit - Intermittent 01501 - Bulb for Blinkers; Rear Left (M6) 006 - Short to Plus - Intermittent 01501 - Bulb for Blinkers; Rear Left (M6) 011 - Open Circuit - Intermittent 02498 - Left Low Beam Reflector Motor (V294) 011 - Open Circuit - Intermittent ------------------------------------------------------------------------------- Address 15: Airbags Labels: VCID: 55A6197BAC12F1965E-FFFE ------------------------------------------------------------------------------- Address 16: Steering wheel Labels: 7L6-953-549.lbl Part No: 7L6 953 549 F Component: J527 3601 Coding: 0010011 Shop #: WSC 31414 790 00001 VCID: 428CD227199C762E0B-8016 No fault code found. ------------------------------------------------------------------------------- Address 17: Instruments Labels: 7L6-920-xxx-7L6.lbl Part No SW: 7L6 920 885 R HW: 7L6 920 885 R Component: J285 KOMBI-INST. 7520 Revision: KHH06V02 Coding: 0007101 Shop #: WSC 00153 935 88063 VCID: 4B92FF032AD6B766F8-801E No fault code found. ------------------------------------------------------------------------------- Address 18: Aux. Heat Labels: 7L6-819-008.lbl Part No: 7L6 815 071 G Component: Standheizung E1MAC 0425 Coding: 0000000 Shop #: WSC 00238 935 88063 VCID: 3664BEF74154DA8EB7-8062 1 Fault Found: 02251 - Heater Unit Locked 000 - - ------------------------------------------------------------------------------- Address 19: CAN Gateway Labels: 6N0-909-901-7L.clb Part No SW: 6N0 909 901 HW: 7L6 920 885 R Component: J533 GW-K-CAN TP20 7520 Coding: 7FE2E78940056002 Shop #: WSC 00153 935 88063 VCID: 70E848EF63B0B4BEAD-8024 No fault code found. ------------------------------------------------------------------------------- Address 22: AWD Labels: None Part No: 0AD 927 755 BG Component: TRANSFERCASE 0126 Shop #: WSC 00000 000 00000 VCID: 010E1D2B5B1AAD3652-5000 No fault code found. ------------------------------------------------------------------------------- Address 34: Level Control Labels: 7Lx-907-553-34.clb Part No: 7L0 907 553 G Component: LUFTFDR.-CDC- 3C3P1 3112 Coding: 0015521 Shop #: WSC 31414 790 00001 VCID: 377AB3F3425E2386AC-8062 1 Fault Found: 01400 - Suspension Level Control 002 - Lower Limit Exceeded - Intermittent ------------------------------------------------------------------------------- Address 46: Central Conv. Labels: 7L0-959-933.lbl Part No: 7L6 959 933 Component: 14 HSG 7124 Coding: 0000069 Shop #: WSC 38200 001 1048576 VCID: 7F0A9BD32DEEDBC624-4A3A Subsystem 1 - Part No: 7L0 959 701 N Component: Tuersteuergeraet FS 6302 Subsystem 2 - Part No: 7L0 959 702 N Component: Tuersteuergeraet BF 6302 Subsystem 3 - Part No: 7L6 959 703 Component: Tuersteuergeraet HL 0202 Subsystem 4 - Part No: 7L6 959 704 Component: Tuersteuergeraet HR 0202 Subsystem 5 - Part No: 7L0 907 719 A Component: Neigungssensor 0020 Subsystem 6 - Part No: 7L6 951 171 B Component: Innenraumsensor 0020 5 Faults Found: 01134 - Alarm Horn (H12) 000 - - 00987 - Lamp for Brake Light; Left (M9) 009 - Open or Short to Ground 00901 - Back-Up Lamps 009 - Open or Short to Ground - Intermittent 01830 - Bulbs for Fog-Lamps; Rear 009 - Open or Short to Ground - Intermittent 00928 - Locking Module for Central Locking; Front Driver Side (F220) 008 - Implausible Signal - Intermittent ------------------------------------------------------------------------------- Address 55: Headlight Range Labels: 7L6-907-357-A.lbl Part No SW: 7L6 907 357 A HW: 7L6 907 357 A Component: AFS-Steuergeraet 0001 Revision: H02 Serial number: Coding: 1288195 Shop #: WSC 31414 790 00001 VCID: 397EB5CB744A35F65A-806C Subsystem 1 - Part No: 7L6 941 329 B Labels: 3D0-941-329.CLB Component: AFS-Lst.-Modul l X008 Coding: 00000019 Subsystem 2 - Part No: 7L6 941 329 B Labels: 3D0-941-329.CLB Component: AFS-Lst.-Modul r X008 Coding: 00000019 1 Fault Found: 02233 - Left Headlight Power Output Stage (J667) 004 - No Signal/Communication - Intermittent Freeze Frame: Fault Status: 00100100 Fault Priority: 2 Fault Frequency: 22 Reset counter: 85 Mileage: 194875 km Time Indication: 0 Date: 2016.10.03 Time: 09:49:27 Freeze Frame: Voltage: 11.50 V Speed: 0.0 km/h ABS 1 ------------------------------------------------------------------------------- Address 56: Radio Labels: 3B7-035-1xx-56.lbl Part No SW: 7L6 035 195 B HW: 7L6 035 195 B Component: Radio DE2 0009 Revision: 00005000 Serial number: VWZ4Z4G1024470 Coding: 0001400 Shop #: WSC 31414 790 00001 VCID: 326C82E7AD3CC6AE9B-8066 No fault code found. ------------------------------------------------------------------------------- Address 68: Wiper Electr. Labels: 7L0-955-119-V2.clb Part No: 7L6 955 119 Component: J400__ Front Wiper 5101 Coding: 0000336 Shop #: WSC 31414 790 00001 VCID: 77FA73F306DEE3866C-8022 Component: RLS nicht vorhanden Coding: 00000000 Shop #: WSC 31414 No fault code found. ------------------------------------------------------------------------------- Address 76: Park Assist Labels: Redir Fail! Part No: 7L0 919 283 F Component: 0D Einparkhilfe 1107 Shop #: WSC 00000 000 00000 VCID: 397EB5CB744A35F65A-806C No fault code found. End-------------------------(Elapsed Time: 03:28)-------------------------- |
22.10.2016, 10:47 (11:47) | #223 |
Добрый день!
Загорелся чек с ошибкой P0113 По расшифровке это "P0113 Датчик температуры воздуха на впуске" Поменял "Bosch 0 281 002 401 Датчик давление во впускном газопроводе", ошибка не пропала, где и какой датчик еще надо сменить? |
22.10.2016, 11:33 (12:33) | #224 |
Поблагодарил(а): 48
Благодарностей: 666
766
Добрый день!
Загорелся чек с ошибкой P0113 По расшифровке это "P0113 Датчик температуры воздуха на впуске" Поменял "Bosch 0 281 002 401 Датчик давление во впускном газопроводе", ошибка не пропала, где и какой датчик еще надо сменить? температура и давление - немного разные вещи... http://www.touareg-club.net/forum/sh...ad.php?t=30808 только менять сразу ненужно... дорогое удовольствие... |
20.11.2016, 15:10 (16:10) | #225 |
По умолчанию двигатель 3tdi
с наступлением холодов постоянно показывает ошибку Р1020 какой датчик менять G247илиN276 подскажите кто в курсе |
15.12.2016, 12:32 (13:32) | #226 |
Доброго времени суток, кто подскажет, перестала работать система старт стоп. Туарег 2010 г.в. 239 л.с двигатель CASA 3.0 TDI. Вася показал вот это Адрес 05: Система санкц. доступа и пуска двигателя Label: 8K0-907-064-05.clb
Номер блока управления: 4H0 907 064 AM HW: 4H0 907 064 J Компонент и/или версия: BCM2 2.0 H13 0208 Кодировка: 05A60000000000000000 Код мастерской: WSC 31414 790 00001 VCID: 74EC20C9D793F0E3C8-8020 1 неисправность: 02823 - Не выполнены условия блокирования ELV 000 - - - Непостоянно Стоп-кадр: Статус неисправности: 00100000 Приоритет неисправности: 5 Частота появления ошибки: 1 Индекс забывания: 252 Пробег: 212756 km Отсчет времени: 0 Дата: 2016.12.10 Время: 11:51:50 |
29.01.2017, 15:04 (16:04) | #227 |
Доброго времени суток!
, нужна помощь при разборе с ошибкой и работой АКПП! Загорелся чек, а при диагностике выскочила ошибка P0733. Коробка прешла в аварийный режим....переключение с R, P, или N идет сразу на D3. Заглушил, завел заново и коробка заработала нормально, чек не погас и на торпеде пропало обозначение номера включенной передачи..... Что может быть? Есть ли какие-то стандартные болячки? На что обратить внимание в первую очередь!? Заранее спасибо за совет и за помощь!! GP, V6 TDI 2008 год. |
Последний раз редактировалось Latyshevda; 29.01.2017 в 17:20. |
30.01.2017, 09:33 (10:33) | #228 |
Поблагодарил(а): 48
Благодарностей: 666
766
, нужна помощь при разборе с ошибкой и работой АКПП! Загорелся чек, а при диагностике выскочила ошибка P0733. Коробка прешла в аварийный режим....переключение с R, P, или N идет сразу на D3. Заглушил, завел заново и коробка заработала нормально, чек не погас и на торпеде пропало обозначение номера включенной передачи..... Что может быть? Есть ли какие-то стандартные болячки? На что обратить внимание в первую очередь!? Заранее спасибо за совет и за помощь!! GP, V6 TDI 2008 год. Затем проводка (поищи, есть тем много... проводка подгнивает в коробах) твоя ошибка 0733 - 3rd gear (wrong ratio, slip) - вот тут https://yadi.sk/i/6e_HmS7837seQZ на 25 стр. поюзай и-нет... вот что на меринах пишут: Возможные причины Русский перевод: Оригинальный (англ): - Low transmission fluid level - Dirty transmission fluid - Shift solenoids - Transmission mechanical problems - Transmission hydraulic control circuit http://obdcode.ru/oshibka-p0733-mercedes-benz.php |
Последний раз редактировалось klf; 30.01.2017 в 09:36. |
16.02.2017, 07:54 (08:54) | #229 |
8
Всем привет!
Приобрёл Васю, но пока в этом деле полный профан, во общем как и в самих турах))) Поверил машинку на ошибки. Помогите понять, есть ли что то серьёзное, что нужно срочно делать. Спасибо. Шасси: 7L (6N0) Список: 01 02 03 05 08 09 15 16 17 18 19 22 34 36 46 55 56 68 6D 76 VIN: WVGZZZ7LZ8D055743 Пробег: 121360km/75409miles 01- Электроника двигателя -- Статус: Периодические ошибки связи 1000 02- Электроника КП -- Статус: содержит неисправности 0010 03- Электроника тормозной системы -- Статус: содержит неисправности 0010 04- Датчик угла поворота рулевого колеса -- Статус: OK 0000 05- Система санкц. доступа и пуска двигателя -- Статус: содержит неисправности 0010 08- Электроника кондиционера / отопителя -- Статус: содержит неисправности 0010 09- Блок управления бортовой сети -- Статус: содержит неисправности 0010 15- Подушки безопасности -- Статус: содержит неисправности 0010 16- Электроника рулевой колонки -- Статус: OK 0000 17- Комбинация приборов -- Статус: содержит неисправности 0010 18- Дополнительный / автономный отопитель -- Статус: содержит неисправности 0010 19- Диагностический интерфейс шин данных -- Статус: содержит неисправности 0010 22- Электроника полного привода -- Статус: содержит неисправности 0010 34- Регулировка дорожного просвета (пневмоподвеска) -- Статус: содержит неисправности 0010 36- Регулировка положения сиденья водителя -- Статус: OK 0000 42- Электроника двери водителя -- Статус: OK 0000 46- Центральный модуль систем комфорта -- Статус: OK 0000 52- Электроника двери переднего пассажира -- Статус: OK 0000 55- Корректор фар -- Статус: содержит неисправности 0010 56- Магнитола -- Статус: OK 0000 62- Электроника задней левой двери -- Статус: OK 0000 68- Электроника стеклоочистителей -- Статус: OK 0000 6D- Электроника крышки багажного отсека -- Статус: OK 0000 72- Электроника задней правой двери -- Статус: OK 0000 76- Парковочный ассистент -- Статус: содержит неисправности 0010 ------------------------------------------------------------------------------- Адрес 01: Электроника двигателя Label: Не найден Part No SW: 070 906 016 DD HW: 070 906 016 DE Компонент: R5 2,5L EDC G000AG 1106 Ревизия: --H06--- Серийный номер: VWX3Z0H1706283 Кодировка: 0010175 Мастерская #: WSC 31414 790 00001 VCID: 55AA7D4DFF2989B6975-5178 Неисправности не найдены. Готовность: 0 0 0 0 0 ------------------------------------------------------------------------------- Адрес 02: Электроника КП Label: 09D-927-750.clb Part No SW: 09D 927 750 CL HW: 09D 927 750 CL Компонент: AL 750 6A 1096 Ревизия: 00H61000 Серийный номер: Кодировка: 0004456 Мастерская #: WSC 31414 790 00001 VCID: 7AF00EF136F786CEDA7-5178 1 неисправность: 01314 - Блок управления двигателя 008 - недостоверный сигнал - Непостоянно Стоп-кадр: Статус неисправности: 00101101 Приоритет неисправности: 2 Частота появления ошибки: 1 Индекс забывания: 0 Пробег: 0 km Отсчет времени: 0 Дата: 2006.01.01 Время: 00:00:01 ------------------------------------------------------------------------------- Адрес 03: Электроника тормозной системы Label: 7L0-907-379-MK25E1.clb Part No SW: 7L0 907 379 L HW: 7L0 907 379 L Компонент: ESP ALLRAD MK25E1 0303 Ревизия: 00H53001 Кодировка: 0000386 Мастерская #: WSC 31414 790 00001 VCID: 4280B61119A70E0EC27-8017 1 неисправность: 01314 - Блок управления двигателя 004 - нет сигнала/связи - Непостоянно Стоп-кадр: Статус неисправности: 00100100 Приоритет неисправности: 2 Частота появления ошибки: 11 Индекс забывания: 57 Пробег: 118889 km Отсчет времени: 0 Дата: 2016.12.14 Время: 11:19:38 Стоп-кадр: Счет: 0 Счет: 12289 Счет: 8194 Счет: 255 ------------------------------------------------------------------------------- Адрес 05: Система санкц. доступа и пуска двигателя Label: 3D0-909-13x-05.clb Part No SW: 3D0 909 139 B HW: 5WK 485 04 Компонент: Kessy 6840 Ревизия: 68406620 Серийный номер: VWX3Z0H1706283 Кодировка: 0000232 Мастерская #: WSC 31414 790 00001 VCID: 285404B99FDBC45EFC3-807D Подсистема 1 - Part No: XXXXXXXXXXX Компонент: ELV XXXX 1 неисправность: 01314 - Блок управления двигателя 004 - нет сигнала/связи - Непостоянно ------------------------------------------------------------------------------- Адрес 08: Электроника кондиционера / отопителя Label: 7L6-907-040.clb Part No: 7L6 907 040 AG Компонент: CLIMAtronic R/L 4331 Кодировка: 0001020 Мастерская #: WSC 00104 935 82279 VCID: 75EA1DCD18E9E9B6B75-8020 1 неисправность: 00819 - Датчик высокого давления-G65 009 - обрыв или короткое замыкание на массу - Непостоянно ------------------------------------------------------------------------------- Адрес 09: Блок управления бортовой сети Label: 7Lx-937-049-V2.clb Part No SW: 7L6 937 049 AF HW: 7L6 937 049 AF Компонент: J519 2000 Ревизия: -0004--- Серийный номер: -------------- Кодировка: 600004003B229C080000000000000000 Мастерская #: WSC 31414 790 00001 VCID: 8004FC19D72B5C1E143-80D5 1 неисправность: 01314 - Блок управления двигателя 004 - нет сигнала/связи - Непостоянно ------------------------------------------------------------------------------- Адрес 15: Подушки безопасности Label: 7L0-959-655.clb Part No SW: 7L0 959 655 HW: 7L0 959 655 Компонент: J234__36 VW8T 0250 Ревизия: 92012025 Серийный номер: 0039P003VWK. Кодировка: 0013110 Мастерская #: WSC 31414 790 00001 VCID: FAF08EF1B1F706CE5A7-80AF 1 неисправность: 01317 - Блок управления в комбинации приборов-J285 004 - нет сигнала/связи - Непостоянно Стоп-кадр: Статус неисправности: 00100100 Приоритет неисправности: 2 Частота появления ошибки: 1 Индекс забывания: 42 Пробег: 121065 km Отсчет времени: 0 Дата: 2017.02.08 Время: 07:20:13 ------------------------------------------------------------------------------- Адрес 16: Электроника рулевой колонки Label: 7L6-953-549.clb Part No: 7L6 953 549 G Компонент: J527 3601 Кодировка: 0010211 Мастерская #: WSC 31414 790 00001 VCID: 438EB31506BD0706C91-8016 Неисправности не найдены. ------------------------------------------------------------------------------- Адрес 17: Комбинация приборов Label: 7L6-920-xxx-7L6.clb Part No SW: 7L6 920 885 R HW: 7L6 920 885 R Компонент: J285 KOMBI-INST. 7520 Ревизия: KHH06V02 Кодировка: 0007101 Мастерская #: WSC 00104 935 89590 VCID: 4B9E9B352AEDCF46311-801E 2 Найдены неисправности: 00446 - Ограничение работы вследствие недостаточного напряжения 002 - нижнее предельное значение не достигнуто - Непостоянно Стоп-кадр: Статус неисправности: 00100010 Приоритет неисправности: 6 Частота появления ошибки: 4 Индекс забывания: 42 Пробег: 120696 km Отсчет времени: 0 Дата: 2017.01.26 Время: 06:40:00 01314 - Блок управления двигателя 004 - нет сигнала/связи - Непостоянно Стоп-кадр: Статус неисправности: 00100100 Приоритет неисправности: 2 Частота появления ошибки: 2 Индекс забывания: 57 Пробег: 120748 km Отсчет времени: 0 Дата: 2017.01.29 Время: 17:05:12 ------------------------------------------------------------------------------- Адрес 18: Дополнительный / автономный отопитель Label: Нет ссылки!! Part No: 7L6 815 071 G Компонент: Standheizung E1MAC 0425 Кодировка: 0000000 Мастерская #: WSC 31414 790 00001 VCID: 3668DAC1416FA2AE7EF-8063 1 неисправность: 01126 - Сигнал частоты вращения коленвала 004 - нет сигнала/связи - Непостоянно ------------------------------------------------------------------------------- Адрес 19: Диагностический интерфейс шин данных Label: 6N0-909-901-7L.clb Part No SW: 6N0 909 901 HW: 7L6 920 885 R Компонент: J533 GW-K-CAN TP20 7520 Кодировка: 7FE2EF9940056002 Мастерская #: WSC 00104 935 89590 VCID: F0E4ACD9E38B4C9EE43-80A5 1 неисправность: 01314 - Блок управления двигателя 004 - нет сигнала/связи - Непостоянно Стоп-кадр: Статус неисправности: 00100100 Приоритет неисправности: 2 Частота появления ошибки: 2 Индекс забывания: 57 Пробег: 120748 km Отсчет времени: 0 Дата: 2017.01.29 Время: 17:05:12 ------------------------------------------------------------------------------- Адрес 22: Электроника полного привода Label: Не найден Part No: 0AD 927 755 BG Компонент: TRANSFERCASE 0126 Мастерская #: WSC 00000 000 00000 VCID: 8102F91DDB2155161BD-5178 1 неисправность: 01314 - Блок управления двигателя 004 - нет сигнала/связи - Непостоянно ------------------------------------------------------------------------------- Адрес 34: Регулировка дорожного просвета (пневмоподвеска) Label: 7Lx-907-553-34.clb Part No: 7L0 907 553 J Компонент: LUFTFDR.-CDC- 3C3P1 3125 Кодировка: 0015521 Мастерская #: WSC 31414 790 00001 VCID: 3A70CEF1717746CE9A7-806F 1 неисправность: 01314 - Блок управления двигателя 004 - нет сигнала/связи - Непостоянно ------------------------------------------------------------------------------- Адрес 36: Регулировка положения сиденья водителя Label: Не найден Part No: 7L0 959 760 Компонент: Sitzverstellung 0702 Мастерская #: WSC 00000 000 00000 VCID: F7F697C582E51BA6259-80A2 Неисправности не найдены. ------------------------------------------------------------------------------- Адрес 46: Центральный модуль систем комфорта Label: 7L0-959-933.clb Part No: 7L6 959 933 A Компонент: 1G HSG 0600 Кодировка: 0000069 Мастерская #: WSC 45043 001 1048576 VCID: 4084BC1910AB1C1ED43-4B00 Подсистема 1 - Part No: 7L0 959 701 N Компонент: Tuersteuergeraet FS 6303 Подсистема 2 - Part No: 7L0 959 702 N Компонент: Tuersteuergeraet BF 6302 Подсистема 3 - Part No: 7L6 959 703 Компонент: Tuersteuergeraet HL 0202 Подсистема 4 - Part No: 7L6 959 704 Компонент: Tuersteuergeraet HR 0202 Подсистема 5 - Part No: 7L0 907 719 A Компонент: Neigungssensor 0020 Подсистема 6 - Part No: 7L6 951 171 B Компонент: Innenraumsensor 0020 Неисправности не найдены. ------------------------------------------------------------------------------- Адрес 55: Корректор фар Label: 7L6-907-357-A.clb Part No SW: 7L6 907 357 A HW: 7L6 907 357 A Компонент: AFS-Steuergeraet 0001 Ревизия: H02 Серийный номер: Кодировка: 1288323 Мастерская #: WSC 31414 790 00001 VCID: 3972D1FD74714DD693D-806C Подсистема 1 - Part No: 7L6 941 329 B Компонент: AFS-Lst.-Modul l X008 Кодировка: 00000019 Подсистема 2 - Part No: 7L6 941 329 B Компонент: AFS-Lst.-Modul r X008 Кодировка: 00000019 1 неисправность: 01314 - Блок управления двигателя 004 - нет сигнала/связи - Непостоянно Стоп-кадр: Статус неисправности: 00100100 Приоритет неисправности: 3 Частота появления ошибки: 11 Индекс забывания: 57 Пробег: 118889 km Отсчет времени: 0 Дата: 2016.12.14 Время: 11:19:38 Стоп-кадр: Напряжение: 11.22 V Скорость: 0.0 km/h ABS 1 ------------------------------------------------------------------------------- Адрес 56: Магнитола Label: 3B7-035-1xx-56.clb Part No SW: 7L6 035 195 B HW: 7L6 035 195 B Компонент: Radio DE2 0009 Ревизия: 00005000 Серийный номер: VWZ4Z4H1037535 Кодировка: 0001400 Мастерская #: WSC 31414 790 00001 VCID: 3260E6D1AD07BE8E527-8067 Неисправности не найдены. ------------------------------------------------------------------------------- Адрес 68: Электроника стеклоочистителей Label: 7L0-955-119-V2.clb Part No: 7L6 955 119 B Компонент: J400__ Front Wiper 5301 Кодировка: 0001397 Мастерская #: WSC 31414 790 00001 VCID: 3972D1FD70714DD693D-806C Подсистема 2 - Part No: 1K0 955 559 AF Label: 1K0-955-559-AF.CLB Компонент: RLS 160108 046 0204 Кодировка: 00208933 Мастерская #: WSC 31414 Неисправности не найдены. ------------------------------------------------------------------------------- Адрес 6D: Электроника крышки багажного отсека Label: Не найден Part No SW: 7L6 959 107 A HW: 7L6 959 107 A Компонент: J605 HECKKLAPPE 1210 Ревизия: --H05--- Серийный номер: --------027338 Кодировка: 0122110 Мастерская #: WSC 31414 790 00001 VCID: 3972D1FD74714DD693D-806C Неисправности не найдены. ------------------------------------------------------------------------------- Адрес 76: Парковочный ассистент Label: 3D0-919-283.clb Part No: 7L0 919 283 F Компонент: 0D Einparkhilfe 1107 Мастерская #: WSC 00000 000 00000 VCID: 3972D1FD74714DD693D-806C 1 неисправность: 00435 - Датчик парковочного ассистента, передний внутренний правый-G333 014 - имеется неисправность/ошибка - Непостоянно Конец ------------------------------------------------------------------- |
16.02.2017, 16:50 (17:50) | #230 |
Поблагодарил(а): 48
Благодарностей: 666
766
сотри все ошибки автоматом....
которые не подтерлись - заходи непосредственно в эти блоки и стирай вручную принудительно... после этого покатайся денёк и запусти еще раз автоскан, и вот тогда уже выкладывай сюда... да.... перед этой процедурой хорошенько заряди аккум (ночь погоняй хотя бы)... и все процедуры с ВАСей проводи только с накинутыми клеммами включенного зарядного устройства!!! |
16.02.2017, 16:58 (17:58) | #231 |
8
16.02.2017, 17:24 (18:24) | #233 |
8
сделай 2 варианта....
просто на зажигании (с подкл.зарядкой) и на работающем... |
24.02.2017, 15:18 (16:18) | #234 |
8
Стёр все ошибки, стало всё кристально чисто. За 3 дня проехал 200 км. и снова считал ошибки. Пока ошибок нет.
27.02.2017, 10:06 (11:06) | #235 |
Поблагодарил(а): 48
Благодарностей: 666
766
не парься... |
01.04.2017, 09:22 (13:22) | #236 |
Добрый День !
Прошу совета. Мои ошибки: VCDS -- Windows Based VAG/VAS Emulator Running on Windows 7 x86 VCDS Version: 15.7.1.0 Data version: 20150904 www.Ross-Tech.com VIN: WVGAE27L77D000951 License Plate: Chassis Type: 7L (7L - VW Touareg (2003 > 11/2006)) Scan: 01 02 03 05 06 08 09 11 13 15 16 17 18 19 1C 22 29 32 34 36 37 39 3C 46 47 55 56 57 64 65 68 69 6C 6D 6E 75 76 77 VIN: WVGAE27L77D000951 Mileage: 175350km-108957miles ------------------------------------------------------------------------------- Address 08: Auto HVAC Labels: 7L6-907-040.clb Part No: 7L6 907 040 T Component: CLIMAtronic R/L 4222 Coding: 0020020 Shop #: WSC 31414 000 00000 VCID: 418EDD2B1B9A6D3612-5000 1 Fault Found: 00003 - Control Module 014 - Defective Freeze Frame: (no units): 2.0 Temperature: 2.0°C Temperature: 21.0°C RPM: 0 /min ------------------------------------------------------------------------------- Address 15: Airbags Labels: 3D0-909-601.lbl Part No: 3D0 909 601 E Component: 0V Airbag 8.4E+ H10 0951 Coding: 0012374 Shop #: WSC 31414 000 00000 VCID: 254669BBEFF2A1160E-5000 2 Faults Found: 01218 - Side Airbag Igniter; Passenger Side (N200) 001 - Upper Limit Exceeded - MIL ON 01217 - Side Airbag Igniter; Driver Side (N199) 001 - Upper Limit Exceeded - MIL ON ------------------------------------------------------------------------------- Address 16: Steering wheel Labels: 7L6-953-549.lbl Part No: 7L6 953 549 H Component: Lenksдulenmodul 3401 Coding: 0010031 Shop #: WSC 31414 000 00000 VCID: 4480D43F0488781E39-5000 1 Fault Found: 00888 - Wiper Switch for Intermittent Operation (E22) 014 - Defective ------------------------------------------------------------------------------- Address 17: Instruments Labels: 7L6-920-xxx-7LA.lbl Part No: 7L6 920 871 H Component: KOMBIINSTRUMENT RB8 2111 Coding: 0007621 Shop #: WSC 31414 000 00000 VCID: 3C70ACDF7C7800DE41-5072 1 Fault Found: 01304 - Radio 004 - No Signal/Communication ------------------------------------------------------------------------------- Address 19: CAN Gateway Labels: 6N0-909-901-19.lbl Part No: 6N0 909 901 Component: Gateway K<>CAN 0101 Coding: 0000006 Shop #: WSC 31414 000 00000 VCID: 70E848EF60B0B4BEAD-5072 1 Fault Found: 01304 - Radio 004 - No Signal/Communication ------------------------------------------------------------------------------- Address 46: Central Conv. Labels: 7L0-959-933.lbl Part No: 7L0 959 933 F Component: X8 HSG 0300 Coding: 0000081 Shop #: WSC 97675 767 92568 VCID: 3F8ADBD36D6E1BC664-4A3A Subsystem 1 - Part No: 7L0 959 701 F Component: Tuersteuergeraet FS 0201 Subsystem 2 - Part No: 7L0 959 702 F Component: Tuersteuergeraet BF 0201 Subsystem 3 - Part No: 7L6 959 703 Component: Tuersteuergeraet HL 0202 Subsystem 4 - Part No: 7L6 959 704 Component: Tuersteuergeraet HR 0202 1 Fault Found: 00132 - Outside Door Handle Illumination/mirror Light Passenger Side 012 - Electrical Fault in Circuit ------------------------------------------------------------------------------- Address 76: Park Assist Labels: Redir Fail! Part No: 7L0 919 283 F Component: 0D Einparkhilfe 1107 Shop #: WSC 00000 000 00000 VCID: 397EB5CB734A35F65A-5072 4 Faults Found: 01629 - Sensor for Parking-Aid; Front Left (G255) 009 - Open or Short to Ground 00435 - Front Right Inner Parking Aid Sensor (G333) 009 - Open or Short to Ground 01548 - Sensor for Parking Aid; Rear Right (G206) 009 - Open or Short to Ground 00436 - Rear Left Inner Parking Aid Sensor (G334) 014 - Defective End-------------------------(Elapsed Time: 10:13)-------------------------- Как я понял по Радио можно забить, т.к. китайская Магнитола стоит. Вот по остальным что ? Особенно по КЛИМЕ что надо делать ? |
03.04.2017, 10:06 (11:06) | #237 |
Поблагодарил(а): 48
Благодарностей: 666
766
Вот по остальным что ? Особенно по КЛИМЕ что надо делать ? по климе - тоже забить! (т.к. подозреваю, что она у тебя работает без нареканий... ) у меня и еще у одного комрада такая же ошибка - всё работает... исправитб пока не смогли... |
03.04.2017, 12:15 (15:15) | #238 |
Поблагодарил(а): 92
7
Доброго дня.
чек горит, ошибка такая: 16434 - Oxygen (Lambda) Sensor B2 S1: Heating Circuit P0050 - 004 - Malfunction / Open Circuit - MIL ON Readiness: 0010 1101 После стирания снова загорается практически сразу. Что это? Конец лямбды, или проводка может где? И я так понимаю это лямбда до катализатора, т.к. после которые программно отключены.. |
15.06.2017, 19:20 (19:20) | #239 |
Touareg 3.6 V6FSI Exclusive
ошибка помогите 00165 в 05 блоке может завистис и глохнут .инагда ключ крутит стартер пока не отключу сам
Последний раз редактировалось audimen4; 15.06.2017 в 19:23. |
09.11.2017, 22:56 (23:56) | #240 |
Поблагодарил(а): 22
15
Добрый вечер. Помогите кто чем может :
Address 19: CAN Gateway Labels: None Control Module Part Number: 7P6 907 530 C HW: 7P6 907 530 A Component and/or Version: GW-CAN-L-MOST H08 5202 Software Coding: 0001037500 Work Shop Code: WSC 31414 790 00001 ASAM Dataset: EV_GatewVW526UDS 001006 (VW52) VCID: 387B2CD38348AA3 7 Faults Found 4230 - No Communications with Steering Angle Sender (G85) U0126 00 [008] - - Intermittent - Confirmed - Tested Since Memory Clear Freeze Frame Fault Status: 00000001 Fault Priority: 2 Fault Frequency: 1 Reset counter: 137 Mileage: 123468 km Date: 2017.11.07 Time: 16:04:49 4160 - No Communications with Airbag Control Module U0151 00 [008] - - Intermittent - Confirmed - Tested Since Memory Clear Freeze Frame Fault Status: 00000001 Fault Priority: 2 Fault Frequency: 1 Reset counter: 137 Mileage: 123468 km Date: 2017.11.07 Time: 16:04:49 5013 - Headlight Range Control Module U101E 00 [008] - No Communication Intermittent - Confirmed - Tested Since Memory Clear Freeze Frame Fault Status: 00000001 Fault Priority: 2 Fault Frequency: 1 Reset counter: 137 Mileage: 123468 km Date: 2017.11.07 Time: 16:04:49 5271 - No Communications with Parking Assist Control Module A U0159 00 [008] - - Intermittent - Confirmed - Tested Since Memory Clear Freeze Frame Fault Status: 00000001 Fault Priority: 2 Fault Frequency: 1 Reset counter: 137 Mileage: 123468 km Date: 2017.11.07 Time: 16:04:49 0259 - Extended CAN Bus (SAE Bus C) U0047 00 [008] - Performance Intermittent - Confirmed - Tested Since Memory Clear Freeze Frame Fault Status: 00000001 Fault Priority: 1 Fault Frequency: 1 Reset counter: 137 Mileage: 123468 km Date: 2017.11.07 Time: 16:04:49 0019 - Terminal 15 U1405 00 [008] - Implausible Signal Intermittent - Confirmed - Tested Since Memory Clear Freeze Frame Fault Status: 00000000 Fault Priority: 0 Fault Frequency: 0 Reset counter: 0 Mileage: 76 km Date: 2017.11.07 Time: 16:04:48 12291 - Energy Management Active U140B 00 [008] - - Intermittent - Confirmed - Tested Since Memory Clear Freeze Frame Fault Status: 00000001 Fault Priority: 7 Fault Frequency: 30 Reset counter: 137 Mileage: 121815 km Date: 2017.10.01 Time: 09:58:34 Address 08: Auto HVAC Labels: None Control Module Part Number: 7P6 HW: 7P6 907 040 BA Component and/or Version: Klima 2 ZoH20 1203 Software Coding: B686000A80 Work Shop Code: WSC 31414 790 00001 ASAM Dataset: EV_AirCondiFront 004001 (VW52) VCID: BD75BDC72C6A0FB 6 Faults Found 0315 - Function Restricted due to Missing Message(s) U1111 00 [008] - - Intermittent - Confirmed - Tested Since Memory Clear Freeze Frame Fault Status: 00000001 Fault Priority: 6 Fault Frequency: 1 Reset counter: 137 Mileage: 123468 km Date: 2017.11.07 Time: 16:04:57 0260 - Function Restricted due to Missing Message(s) U1111 00 [008] - - Intermittent - Confirmed - Tested Since Memory Clear Freeze Frame Fault Status: 00000000 Fault Priority: 0 Fault Frequency: 0 Reset counter: 0 Mileage: 76 km Date: 2017.11.07 Time: 16:04:57 0291 - Function Restricted due to Missing Message(s) U1111 00 [008] - - Intermittent - Confirmed - Tested Since Memory Clear Freeze Frame Fault Status: 00000001 Fault Priority: 6 Fault Frequency: 1 Reset counter: 137 Mileage: 123468 km Date: 2017.11.07 Time: 16:04:55 0325 - Control Module for Auxiliary Heater B10C0 16 [008] - Voltage Too Low Intermittent - Confirmed - Tested Since Memory Clear Freeze Frame Fault Status: 00000001 Fault Priority: 3 Fault Frequency: 3 Reset counter: 136 Mileage: 122384 km Date: 2017.10.12 Time: 18:12:48 0243 - Function Restriction due to Received Malfunction Value U1113 00 [008] - - Intermittent - Confirmed - Tested Since Memory Clear Freeze Frame Fault Status: 00000001 Fault Priority: 6 Fault Frequency: 41 Reset counter: 139 Mileage: 122363 km Date: 2017.10.11 Time: 20:51:28 0409 - Function Restricted due to Missing Message(s) U1111 00 [008] - - Intermittent - Confirmed - Tested Since Memory Clear Freeze Frame Fault Status: 00000001 Fault Priority: 6 Fault Frequency: 1 Reset counter: 137 Mileage: 123468 km Date: 2017.11.07 Time: 16:04:52 Address 34: Level Control Labels: None Control Module Part Number: 7P0 907 553 K HW: 7P0 907 553 K Component and/or Version: PASM H01 1110 Software Coding: 14210000 Work Shop Code: WSC 31414 790 00001 ASAM Dataset: EV_PASMConti 001004 (VW52) VCID: 3F8947CFA6669DB 3 Faults Found 0786 - Electical Consumer Cut-Off Active U1402 00 [008] - - Intermittent - Confirmed - Tested Since Memory Clear Freeze Frame Fault Status: 00000001 Fault Priority: 2 Fault Frequency: 137 Reset counter: 1 Mileage: 775936 km Date: 2032.10.15 Time: 09:12:61 0628 - Function Restricted due to Insufficient Voltage U1400 00 [008] - - Intermittent - Confirmed - Tested Since Memory Clear Freeze Frame Fault Status: 00000001 Fault Priority: 2 Fault Frequency: 136 Reset counter: 1 Mileage: 134144 km Date: 2049.02.31 Time: 10:16:54 0789 - Control Head for Level Conrtol System C10D4 31 [008] - No Signal Intermittent - Confirmed - Tested Since Memory Clear Freeze Frame Fault Status: 00000001 Fault Priority: 1 Fault Frequency: 137 Reset counter: 1 Mileage: 150528 km Date: 2051.12.00 Time: 19:44:57 Address 69: Trailer Labels: None Control Module Part Number: 7P0 907 383 G HW: 7P0 907 383 C Component and/or Version: Anhaenger H09 0110 Software Coding: 0106040000000000 Work Shop Code: WSC 31414 790 00001 VCID: 3C7330C3BF70863 1 Fault Found 00576 - Terminal 15 008 - Implausible Signal - Intermittent Freeze Frame Fault Status: 00101000 Fault Priority: 3 Fault Frequency: 1 Reset counter: 137 Mileage: 123468 km Time Indication: 0 Date: 2017.11.07 Time: 16:04:51 |
