09.10.2018, 17:33 (16:33) | #1 |
Retrofit bi-xenon adaptive on low bi-xenon on facelift model
Hello,
Sorry for writing in english, but I'm not Russian nor I speak Russian language, I'm from Romania and Iv'e decided to use google-translate in order to join this awesome community. I want to retrofit adaptive bi-xenon, code 8IM, to my low bi-xenon equipment, 8IH. The facelift touareg, 2015+ comes with a standard xenon equipment, so the plugs are the same they have 14pins, also I've look at ETKA and for the harness for the headlight it seems it is the same cable for both equipments, 8IM and 8IH, but maybe I'm wrong, I would highly appreciate if someone can confirm this. Besides the harness I'm wondering what are the coding that i need to do to BCM1 in order to activate the AFS and the DRL led. As a remark If i connect right now the 8IM headlights, everything works, except the DRL and the leveling, where I get and error on vcds regarding the leveling. Also most likely I must buy a new BCM, I've bought this one 4h0 907 063 DA from a car that has 8IM equipment but also has adjustable suspension, so I'm not sure if this one would fit also. Looking forward for your help! |
29.11.2018, 15:53 (14:53) | #3 |
I come with some updates, the leveling sensors are not connected to the leveling unit but they are connected directly to the bordnetz and the leveling software is incorporated into the bordnetz so i will have to buy a leveling unit.
